JetCat P100-RX **New-In-Box**
My Feedback: (36)
For sale is a factory new JetCat P100-RX turbine. The GSU is included, but turbine batteries are no longer included with JetCat engines. The serial number is 100-4148. This engine retails for $2425 plus shipping.
Shipping is FREE in CONUS, or paid by the buyer outside of the USA.
From JetCat:
The completely redesigned V10.0 ECU is three times smaller than the V6.0 ECU, yet has all its proven capabilities and more at a weight of only 26g!
The updated ECU comprises a high speed digital power bus for control and power supply of all engine peripherals (e.g. engine, fuel pump, solenoids, smoke pump, lighting systems, etc. ) with a minimum of wiring connections.
An on board precision pressure and ambient temperature sensor allows for optimum engine control, independent to environmental conditions.
From JetCat:
- Compact outline and form factor
- Internal kerosene start
- Internal EGT sensor!
- Internal solenoids, only one fuel connection to the engine
- New "Bus-system" fuel pump.
- Eliminates necessity to adjust pump startup voltage!
- Single wiring connection from ECU to engine
- New miniature/lightweight ECU V10.0
- Battery: 3-cell LiFePo
- Weight: 1050gr
- Diameter: 97mm
- Length: 245mm
- Thrust: 100N @152000 1/min
