JP Hobby ER-150 S Metal Struts Set + Brakes
New never mounted JP Hobby ER-150 S Metal Struts Set + Brakes (For planes up to 20kg)
CNC Machined Aluminum articulated and hydraulic suspended landing gear complete set including 86 and 63mm wheels with JP Hobby brakes system and sequenced retracts. Main gear and single nose gear.
Specifications
Materials: Aluminum
Struts diameter: 18mm
Main gear wheels axle diameter: 8mm
Nose gear wheel axle diameter: 6mm
Main gears wheels diameter: 86mm
Nose gear wheel diameter: 63mm
Weight: 1610 g (for the complete set including the struts, wheels and the 2 modules)
Dimensions: for detailed dimensions, please refer to the pictures
Suspension: hydraulic
Wheels: ball bearings mounted
Servo size for steering nose wheel : 40x 20x 37mm size with 3.8 to 8kg torque such as the KST MS1035 (not included)
Contents
2x Scale metal struts for main landing gear equipped with aluminum retracts, 86mm wheels & brakes system
1x Scale metal strut for nose gear equipped with aluminum retract and 63mm wheel
1x Electronic sequencer module for retracts and gears doors (V1 type) as well as Electronic brakes control (all in one)
**Asking $550 plus fees and a little shipping. Save over $250 link below. Selling because I have no use for them.***
https://www.jphobby.eu/en/struts-ful...p-to-20kg.html
paypal [email protected]
Specifications
Materials: Aluminum
Contents
