Great Planes Revolver 70" O.S. 120
VA
For sale Great Planes Revolver 70" wingspan. O.S. 120 4 stroke engine, Landing gear was reinforced per the threads on R/C Universe. Futaba 9202 servos on all surfaces except the rudder has a Hitec 645. There's only normal hanger rash except where I dropped the canopy and cracked the back of it. Add your RX and battery.
Local Pick up only in or near 22657.
I got that but you would still have them hooked up on the same side, not on opposite sides as it appears you have done. Putting them on opposite sides means you need a servo reverser or a mix function that does it. I'm curious why do it that way? Or is it that the servos are just way out of whack since the elevators definitely are?
VA
The way G.P. said to set up the elevators was with 2 pushrods connected with a wheel coller. I didn't like that set up so I put 2 servos with a mix in the radio. Any 6ch. radio can do it. The elevators are not out of whack, that's just where the servos were sitting when I took the pic.
