Vintage RPS Yokomo Special Edition Dogfighter YZ-834B 4wd RC Car
Hello there, you are viewing a rare, used, Vintage RPS Yokomo Special Edition Dogfighter YZ-834B 4wd RC Car.
This car has been sitting for many years. I have tested it and everything works great.
It has a Futaba junior magnum transmitter and receiver.
Comes with a brand new body along with hundreds of dollars worth of NOS (new old stock) parts. The extra body and instruction manual have a couple of small spots on them that look like something like stain was dripped on them.
Here is a list of the parts that will come with it:
3 ZB-2N front suspension arms
1 ZB-20 servo saver linkage
1 ZB-44 rear anti-roll stabilizer bar mount
2 ZB-28 46 tooth differential spur gears
2 ZB-35N gear set with steel shafts
1 ZB-12 4mm X 8mm bushings
6 ZB-5 hub carrier sets
3 ZB-6 steering blocks
3 ZB-8E e clips for front axle
2 ZB-41 drive chains
1 ZB-1 front bulkhead
1 ZB-34 gear box
1 ZB-40 12 and 13 tooth dog fighter sprocket set
1 ZB-23N rear reinforced suspension arm set
1 ZB-09 front drive shaft set
1 ZB-25 rear drive shaft set
1 ZB-42 upper chain guide
1 ZB-19 servo saver with set screws and nuts
1 ZB-50 rear wing set (red)
Also included is the original instruction manual, assembly manual, R.P.S. parts list, rear suspension retainers and a used Yokomo O5R Stock motor with two sets of new brushes and a set of brush springs.
I bench tested the extra motor and it works fine.
You will receive everything as stated.
1 ZB-34 gear box
