Saito FG-17 (100) 4-Stroke Gas Engine
My Feedback: (48)
Slightly used FG-17, excellent compression, starts easy every time. Very reliable and great performance. Come with extra new spark plug. Free shipping to CONUS only. PayPal add 3% fee.
This is the Saito Engines FG-17 (100) 4-Stroke Gas Engine. Saito is continuing to expand their gasoline engine line with the addition of the FG-17cc 4-stroke engine. The FG-17cc is a low operating cost version of Saito's most popular engine, the FA-100, with the same performance. This new engine uses the latest pump carb technology from Saito, inset valve seats as well as a new style ignition system. The FG-17cc is ideal for any .60 size model or any model currently using the FA-100. Like all Saito engines, these powerhouses are engineered with the same quality and reliability that Saito fans have come to know and trust.
Features:
Gasoline engine lowers operating costs as much as 90%
Electronic ignition included for easy start-ups
Specifications:
Fuel Type: Gas
Cylinders: Single
Displacement: 1.05 cu. in. (17.20 cc)
Type: 4-stroke
Bore: 1.14 in (29.0mm)
Stroke: 1.02 in (26.0mm)
Total Weight: 27.2 oz (770 g)
Muffler Weight: 2.1 oz (60 g)
Ignition Weight: 3.5 oz (100g)
Crankshaft Threads: 8 x 1.25mm
Muffler Threads: 12mm
Benchmark Prop: 15 x 6 @ 9200 rpm
Prop Range: 14 x 8 - 16 x 6
RPM Range: 2,000 - 9,500
Oil Type & Content: Gas-oil mix of 20:1
Muffler Type: Cast
Cylinder Type: AAC with Ring
Carb Type: 2 Needle Saito Gas Carburetor
Crank Type: Threaded
Plug Type: Four Stroke 1/4-32 plug
Features:
Specifications:
Fuel Type: Gas
Cylinders: Single
Type: 4-stroke
Muffler Type: Cast
