ATJ220sv turbine
ATJ220sv turbine
This turbine is very powerful with 48.5 lbs thrust and has 9hrs.7mins run time. Comes with no warranty and sold as is. This can be serviced at Crx turbines . Come with everything in the photos including manual but no battery. Asking 1450 shipped. Priced to sell thank you.
ATJ220SV Turbine engine Specifications
Dimensions : Outer Diameter 112mm; Length: 293mm
Weight : 1780grams (including starter)
Maximum thrust : 22KG @ 123,000rpm
Idle RPM : 35,000 Idle thrust @ 35,000 : 0.85KG
EGT : 430 - 630 degree C ,
Fuel Consumption : @ max rpm 650 gms/min ,
Fuel/ oil : Jet fuel or Kerosene or Diesel + 5% oil (synthetic turbine engine oil)
ATJ220SV Engine package include
1. Turbine engine
2. Engine Mount set
3. Fuel pump set
4. ECU ( Xicoy V10 Kerostart )
5. GSU (Xicoy small type GSU for V10 ECU )
6. Fuel filter
7. FOD screen
8. Electronic cables
9. User's manual
paypal [email protected]
1. Turbine engine
2. Engine Mount set
3. Fuel pump set
6. Fuel filter
7. FOD screen
9. User's manual
