DLE61 Gas Engine
My Feedback: (12)
DLE61 Gas Engine
This is a used DLE-61 Gasoline Engine with Electronic Ignition. Never crashed and has about 20 flights on it.
Free Shipping
FEATURESElectronic ignition delivers smooth idle, easy starting andFree Shipping
powerful throttle transition, spiral wire wrap eliminates
interference
Muffler designed for optimized power delivery
Enlarged crankshaft ball bearings
Two petal reed valve induction system
Airplane specific carburetor with manual choke
Lightweight piston for fast acceleration, excellent compression and
low vibration
INCLUDESDLE-61 Gasoline Engine with Electronic Ignition, NGK CM6 Spark Plug,
Electronic Ignition, Muffler, four 2.7 (68mm) Standoffs
SPECIFICATIONSDisplacement: 3.7 cu in (61.0 cc)
Bore: 1.85 (47mm)
Stroke: 1.38 (35mm)
Compression Ratio: 10.5:1
Performance: 6 HP7,500RPM
Idle Speed: 1,400 RPM
Overall Weight: 4 lbs (1814g)
Engine Weight: 3.02lbs (1370g)
Muffler Weight: 3.9oz (110g)
Ignition Module Weight: 3.9oz (110g)
Engine Mount Standoff Weight: 4.5oz (128g)
Distance between top Horizontal Mounting Hole Centers: 3.54 (90mm)
Distance between Vertical Mounting Hole Centers: 2.64 (67mm)
Distancebottom Horizontal Mounting Hole Centers: 2.83 (72mm)
HeightCrankshaft center to top of Cylinder Head: 4.96 (126mm)
Backplate to outer edge of Prop Drive Hub: 6.77 (172mm)
Outer edge of Standoff to outer edge of Prop Drive Hub: 9.45 (240mm)
Standoff Length: 2.68 (68mm)
Spark Plug Gap: 0.018 - 0.020 (0.45mm - 0.51mm)
