A Very Nice--Used ONCE Paasche Talon TS Airbrush
My Feedback: (223)
My painting days with an airbrush are over. This is effectively new.
Includes Handbooks and Siphon Bottle.
$40 Shipped. Good Deal!
Talon TS Airbrush
The siphon feed airbrush features a chrome plated body and aluminum anodized cutaway handle. The TS#3L is installed with the .66mm head and can achieve detail down to 1/64 inch and using our optional fan head wider patterns up to 3 inches. A PTFE packing enables the TS to handle any water or solvent based paint. Clean up is as simple as spraying your paint cleaner though the airbrush and wiping of the needle. The TS can be used for many applications including hobby, craft, automotive, t-shirts, taxidermy, ceramics, cake decorating, tanning, tattoos, etc. The TS airbrush is made in the US.
Features:
Highly polished & hardened stainless steel needles for long life and reduced clogging
Solvent proof needle packing allow spraying of water & solvent based paints
Removable needle protector for fine detail spraying
Anodized aluminum handle
Chrome plated body
Specifications:
Model Talon TS
Type Double action, Internal mix, Siphon feed
Head Size Size 1 (.25 mm)
Size 2 (.38 mm)
Size 3 (.66 mm)
Fluid Packing PTFE (Teflon) - For spraying solvent or water based fluids
Air Volume 20 PSI @ .5 CFM
Air Pressure 20-75 PSI
Spray Pattern 1/64" to 1 1/2"
Bottle size 1/2" to 8 oz Bottles available
Air Inlet ¼-20 Thread (Fits Paasche Hose) - adapters available
Weight .5 lbs
Finish Chrome plated body
Talon TS Airbrush
Features:
Chrome plated body
Specifications:
Model Talon TS
Size 2 (.38 mm)
Size 3 (.66 mm)
Weight .5 lbs
