Eflite Platinum P-51B 32e
My Feedback: (53)
Eflite Plantinum P-51B Mustang 32e NIB. Preference give to local pick up in Portage, MI. Shipping and insurance will be buyers cost if I ship.
Specifications:
Type: Brushless Outrunner
Size: Replacement for a 30- to 32 size glow engine
Bearings or Bushings: Ball Bearings
Wire Gauge: 14
Recommended Prop Range: 11x7 to 14x10
Voltage: 12 - 16.8
RPM/Volt (Kv): 770
Resistance (Ri): .02 ohms
Idle Current (Io): 2.40A @ 10V
Continuous Current: 42A
Maximum Burst Current: 60A (15 sec)
Cells: 10-14 Ni-MH/Ni-Cd or 3-4S Li-Po
Speed Control: 60A Brushless
Weight: 200g (7.0 oz)
Overall Diameter: 42mm (1.70 in)
Shaft Diameter: 5mm (.20 in)
Overall Length: 50mm (1.90 in)
o Equivalent to a 30- to 36-size glow engine for sport and scale airplanes weighing 3.5-6 lb (1.6-2.7 kg)
o Ideal for 25- to 36-size 3D airplanes up to 4.5 lb (2 kg)
o Ideal for models requiring up to 700 watts of power
Wingspan: 52.0 in (1320mm) Wing Area: 460 sq in (29.7 sq dm) Length: 45.5 in (1160mm) Weight with Battery: 5.25-6.00 lb (2.40-2.70 kg) Weight w/o Battery: 4.50-5.00 lb (2.00-2.30 kg)
Specifications:
Wire Gauge: 14
Voltage: 12 - 16.8
RPM/Volt (Kv): 770
AZ
P-51 eflite
Specifications:
Wire Gauge: 14
Voltage: 12 - 16.8
RPM/Volt (Kv): 770
Specifications:
Wire Gauge: 14
Voltage: 12 - 16.8
RPM/Volt (Kv): 770
