nib-HFD-08RD 8ch FM 40Mhz "Supreme" receiver
My Feedback: (12)
First Introduced in 1993 the Supreme became the world's most popular and most dependable aftermarket receiver. The Supreme receiver was available in a connector and shift compatible version for use with all modern FM transmitters.
. Crystal - The Hitec receiver is "center tuned"and will accept any Hitec dual conversion crystal (within same band) without re-tuning - other brand crystals are not compatible.
. Usage: Air ...Class: Standard...Channels: 8...Modulation: FM ...Frequency: various
. General Specs: Digital:No ... Range: 5280 feet... Receiver Shift:Yes... Voltage: 4.8 - 6.0... Current Drain: 19 mA +/- 3.0 mA... 1.34 ounces ...2.30 x1.40x.80 inches... Applications: - Pattern/Aerobatics - Standard Airplane - All Purpose.
. Refer previous answer:
HFD-08RD = Supreme
[NB: This is the one HFS-08RD on 72 mhz being a 7ch shift selectable via a jumper to enable switching between negative (Hitec & Futaba) and positive (JR/Airtronics) shift.
I will sell this NIB receiver for $20.00 + $5.45 S&H. I take Pay Pal at [email protected]. I will take apersonal check but not a Money Order or cashiers check.
HFD-08RD = Supreme
