Spektrum AR12310T 12 channel Receiver with SPMAS3000 Gyro
FL
This is a like new system. Used in a large Jet.
About Spektrum AR20300T
The Spektrum AR20300T PowerSafe receiver is a feature-packed 20 channel receiver with integrated full-range telemetry. Each come with built-in connection ports for RPM, Flight Pack Voltage and Temperature sensors as well as an X-Bus port for additional telemetry options. If you have a DSMX/DSM2 transmitter capable of 11ms frame rates, the AR20300T will deliver lightning-fast input-to-output response that is perfect for high-performance applications such as aggressive 3D , IMAC and Turbine Airplanes.Each receiver includes 3 remote receivers that take advantage of Spektrum MultiLink technology. This patented technology eliminates the reflected signal fading and antenna blind spots that can affect all 2.4GHz systems. A ground-breaking feature introduced on the AR20300T PowerSafe Receiver is the built in receiver battery energy sensors. Giving pilots added awareness of the load and mAh used by the servos, retracts, lights, etc. used by each battery.
Current Gen 2 Radio firmware already supports this function. Also, as with most of the current receiver line up, these feature a bind button that gives pilots an easy alternative to the age old bind plug.
Spektrum AR20300T Features
- Binding is easier than ever by Binding through a button or familiar bind plug
- Sensor port allows the receiver to be upgraded with future Spektrum add-ons
- Compatible with all Spektrum DSM2 and DSMX transmitters
- Rubber grommet hard mounts and minimalistic labeling helps produce the cleanest model setups
- Capable of 11ms frame rates
- Integrated telemetry with built-in ports for RPM, flight pack voltage, temperature sensors and X-bus for telemetry sensor expansion
- Receiver pack energy & voltage sensor and flight log data available without the need for additional sensors
- PowerSafe redundancy system with dual 13 AWG battery leads with EC3 connectors. Perfect for power hungry aircraft and high current applications
- Not compatible with DSM2 AIRMOD JR Module (SPMMSJR720)
My Feedback: (41)
The rx is a 12 channel by the pictures but your ad describes a 20 channel? Also, there's no off/on switch shown? Lot of money for a used 12 channel even if it does have an AS3000.....
FL
You are right I copied the wrong receiver specs... Headline shows what it is... I will try to change it. Reason price is high is that they are impossible to get. If you want one new, you may have to wait a few months.
