Go Back  RCU Forums > Marketplace
Reload this Page >
EME Gas Engine Auto Start Kit (50-60cc) for DLE55 DLE55RA EME55 EME60 RC Engine
Old 11-30-2021, 12:30 PM
WWIIP38
My Feedback: (43)
Default EME Gas Engine Auto Start Kit (50-60cc) for DLE55 DLE55RA EME55 EME60 RC Engine
100% New In Box
RC Airplane Electric Starter Kit for
DLE55 / DLE55RA / EME55 / EME 60 / DLA56
RC Plane Gasoline Engine
PLUS: S-12 switch (100 amp controller) and gear lube
Remote start your engine with a switch of your transmitter. This is possible when using an electric on-board starter!
The kit incorporates a special one way bearing so power is not transferred back to the electric motor when the engine starts.
The auto start unit will require an auto start switch and a battery, 3-15v (12v is recommended) and leads have to be soldered to the motor.
Compatible with the following engines:
EME55, EME60, DL50, DLE55, DLA56, SE55 plus similar engines
(Note that the DLE55RA requires drilling one new mounting hole).
Features:
  • Strong and robust
  • Beautifully engineered
  • Fitted with a powerful brushed 550 motor
  • Strong one way bearing
  • Supplied with necessary mounting hardware
Specs:
  • Voltage: 3~15v (12v recommended)
  • Suits Engines: 50~60cc
  • Weight: 540g (19oz)
  • Motor Size: 37.5mm Diameter and 57mm in length
  • Use on DLE55, EME55, DLA56, SE55, EME60
  • Color: Blue
  • PayPal and USPS money order accepted
  • Shipping - 48 states - $10.00
WWIIP38 is online now
Old 11-30-2021, 05:52 PM
niteflyer
I'll take it, send payment info......... Thanks
niteflyer is offline
Old 11-30-2021, 06:09 PM
WWIIP38
My Feedback: (43)
Ok, you got it!
PM sent.
