3d printed Kingtech ECU v4 mount
This is a ECU mount for Kingtech. Printed in ABS
How it works: There are hexagon indents in the backplate for 2 nuts to be glued. Then mount the ECU using screws.
You can then Hysol the mount anywhere in the plane. You can remove the ECU whenever, the mount is permanent.
There are 2 versions, 45 degree angled, and flat. Let me know which you want.
