Go Back  RCU Forums > Marketplace
Reload this Page >
Rainbow-Tronic Moki Radial Complete Ignition Set - PLUG AND PLAY
Old 06-25-2022, 03:43 PM
marksp
My Feedback: (9)
marksp's Avatar
Default Rainbow-Tronic Moki Radial Complete Ignition Set - PLUG AND PLAY
Unused Rainbow-tronic DIS 5* -5 ignition & DZS_2 Switch for Moki 215/250. I purchased and intended to upgrade but old system continues to run and I'm too lazy to rip model apart! All you need is a 3S LiPo to power ignition. Price include shipping USPS Priority CONUS Paypal
Rainbow-Tronic ignition systems fire several spark in quick sequence at start-up.
Once the motor enters idle this ignition will employ the multi-spark mode once again to ensure a smooth idle on all cylinders. The coils sit external, this setup completely replaces the Moki system, from sensor cable to ignition to coils to leads to spark plug caps.
Since the sensor cable takes its impulse from the crank it does fire an extra spark per exhaust cycle but leads to the spark plugs running cleaner (especially the ones on the bottom) as they continuously get zapped.
When the motor revs at 6000 rpm we are looking at 30.000 sparks per minute. Even at full throttle you have the same strong spark as on idle, an industry first.
Furthermore Rainbow-tronic feature rpm limiters (important for those on adjustable pitch props), status LED and battery monitor function and fail-safe timeout.
marksp is offline
