gear to get this 25e flying
Never flown. I completed almost all of the build--I did not install the optional lighting kit.
I'd recommend you go through the Assembly Manual, step-by-step to be certain that everything is properly mounted and tightened. The Velcro strips holding the ESC and other parts may need replacing as the sticky may be gone.
The plane will need to be balanced for center of gravity and adjusted for control throws before flying.
Power 32 Motor Setup
EFLM4032A Power 32 Brushless Outrunner Motor, 770Kv &60
EFLA1060 60-Amp Pro Switch-Mode BEC Brushless ESC $65
EFLB32004S30 3200mAh 4S 14.8V 30C Li-Po, 12AWG EC3 $40
APC13065E 13 × 6.5E Electric Propeller $3
SPM8800 DX8 DSMX 8CH $200
EFLA110 Power Meter $30
EFLC3020 Celectra 200W DC Multi-Chemistry Battery Charger $90
EFLSP200 2-inch Aluminum Spinner with 4mm and 5mm Collets $15
SPMAR7010 AR7010 7CH DSMX(TM) Receiver $50
SPMSA5030 A5030 Mini Digital Aircraft Servo (6) $40ea
SPMA3051 6-in (152mm) Servo Extension (2) (Aileron wing extensions) $4ea
SPMA3052 9-in (229mm) Servo Extension (ESC extension) $6
SPMA3053 12-in (305mm) Servo Extension (2) (Aileron to fuse extensions) $4ea
SPMA3050 3-inch (152mm) Servo Extension (Bind plug extension) $4
SPMA3058 Standard Y-Harness (Receiver to flap fuselage extension) $9
Happy to deal!!!! peter
I do. I was hoping to sell the entire lot, but would consider breaking it up.
I just posted this yesterday, so would like to wait a bit to see if I get such an offer.
I will certainly get back to you.
thanks.....peter
thanks.....peter
