Lanier F-86 propjet
My Feedback: (131)
Lanier F-86 propjet
NIB LANIER RC AIRPLANE F-86D Sabre ARF
F-86 Dognose Sabre ARF/ Radio Controlled, Glow Powered, Almost-Ready-to-Fly, Lanier F-86D Sabre .40 stand-off Scale Airplane. Construction: One Piece fuselage, vertical stabilizer and belly pan are painted fiberglass. Wings: Two-piece built-up balsa with spars secured to fuselage with two 4mm wing bolts and washers. Rearward sweep of 35°. Covering: factory applied covering on wings and horizontal stabilizer. Color scheme is Gray with diagonal Yellow stripe on fuselage and Yellow stripe on vertical stabilizer. Radio Compartment: Plywood reinforced. Cowling: Fiberglass, pre-painted to match wings and fuselage. Canopy: Clear, single. Landing Gear: Fixed .19" (3mm) pre-formed wire, Ailerons: Controlled by standard size servo mounted in each wing
