Electron GS200 gear controller,my screen is frozen
Electron GS200 gear controller,my screen is frozen...new or used
......john 727 712 7748
My Feedback: (37)
The Electron GS-200 is the same unit but is less programmable and slightly more expensive than the Xicoy LGC15.
Dreamworks shows out of stock but the Xicoy LGC15 is a better buy.
https://dreamworksrc.com/product/lgc...and-sequencer/
My Feedback: (37)
The Xicoy controller will work with any electric gear as you can adjust the maximum amp output of the controller for the main and nose retract units.
The Electron GS-200 controller is the Xicoy unit but the max amp output is set for Electron retracts and can not be adjusted.
I have one plane with Electron retracts, two with Dreamworks Pro-Link mains and Electron nose retracts and one with Sab Avio retracts.
I use the Xicoy LGC15 controller on all of them.
My Feedback: (37)
If you still need the controller I may have an Electron GS200 controller.
Will check when I get back from GA Jets.
You can text me at 828-308-8497 or email at [email protected]
