NEW KingTech K-210 G2 Turbine Engine 210
My Feedback: (15)
KingTech G series, a true Fuel Start turbine, will start and run on Diesel, Kerosene, and JetA. G series have both solenoid valves built into the front cover, with a single fuel feed that eliminates at least 8 fuel connections upstream to the turbine, making a clean engine install a very simple task.
NIB
K210G2
set includes KingTech ECU, GSU, ECU cable, KP500V pump, cable set, fuel filter, 4mm connection assortment pack and 4mm shout-off valve
Specifications:
Diameter: 112.6 mm (4.43")
Length: 286 mm (11.26")
Weight: 1650 g (3 lb. 10oz. )
RPM Range: 33,000-120,000RPM
Thrust: 21 kg @ max RPM ( 46.3 lbs at max RPM)
EGT: 650°C max
Fuel consumption: 590 g / min ( 20.8 oz / min )
Fuel: Diesel, Jet A1, Kerosene
Lubrication: 5%
NIB
K210G2
Specifications:
EGT: 650°C max
Lubrication: 5%
