Go Back  RCU Forums > Marketplace
Reload this Page >
Carbon propeller for Free Flight models F1C
Old 09-28-2022, 03:58 AM
Maksim
Maksim's Avatar
Default Carbon propeller for Free Flight models F1C
Carbon propeller for Free Flight models F1C.
Manufactured from high modulus carbon fiber and quality German epoxy resin in high pressure metal molds.
After manufacturing, this product is heat treated and final balanced.
Standard reference propeller on many of the winning models of recent years.
Type 1 (ready to use)
Diameter - 180mm.
Pitch - 76mm with a hub with a center distance of 28mm.
The hub is available with a center distance of 28mm or 29mm - your choice.
Hub thickness - 6mm.
The hole in the hub is 8mm and it is possible to put an adapter under the shaft 6mm
Weight - 8.2 - 8.4g.
Available - 3 pcs.
Priese - 45$/pcs.
Type 1 (set of blades)
Height of the hub in the blade - 9mm.
Hub hole - 2.50mm.
Weight pairs of blades - 4.0g.
Available - 6 pcs.
Priese - 30$/pairs of blades
Type 2 (ready to use)
Diameter - 182mm.
Pitch - 77mm with a hub with a center distance of 29mm.
Available - 3 pcs.
Priese - 45$/pcs.
Type 2 (set of blades)
Hub hole - 2.50mm.
Available - 6 pcs.
Priese - 30$/pairs of blades.
Worldwide shipping - 11$.
Accept PayPal.
Use quality products made in Ukraine)
Maksim is offline
