ARTF: Custom Giant Twin Engine Stik 112.5" WS
My Feedback: (25)
OL: 82.0"
OW: 112.5" (3-piece wing with TNT wing tubes)
Centre Section: 36.5"
Outer Wing Panels: 38.0"
Dry Weight: 25.0 lbs.
Time to list another RC aircraft, with the sale of my custom Giant Twin Engine Stik. We all know how well a Don Anderson designed Stik flies, regardless of size or even how its powered! Learn how to fly a twin engine aircraft without risking your prized scale twin engine project! Here's what's included in the sale:
-Don Anderson Giant Stik plans enlarged/modified by Roger Marshall for twin engine operation.
-Three-piece wing set-up allows transportation of the Stik on its own gear, only one servo to hook-up on each outer wing panel at the field!
-twin DLE-35RA rear exhaust engines each w/Bowman rings & Tech-Aero IBEC.
-Pilot 32oz. main tank with Dubro 4 oz. header tank in each nacelle.
-both 4.0" 3-blade & spare 4.0" 2-blade aluminum spinners.
-four Turnigy Laminated 17" x 8" 3-blade props.
-Valley View enlarged Walbro carb instead of DLE version & fuel dot.
-Engines bench run only to sync both high/low needle set-up.
-CB Associates 4.5" main & tail wheel assembly.
-Combination Monocoat & Hangar 9 red/white covering used on top surfaces & fuselage. High visibility black/white/red checkerboard on underside of wing. German WW-1 Black crosses added with "Skull & Crossbones" on rudder.
-TNT aluminum main landing gear with Bennett Built 1/4" LG reinforcement system for those "less than perfect" landings!
-Spektrum AR20310T 20 channel receiver with AS3X gyro module and three satellite receivers.
-two Electro Dynamics 6.6v 2,500 mAH Life batteries w/HD switches.
-Futaba S-9202 servos w/aluminum servo arms on ailerons.
-Hitec HS-5645MG Digital servos w/aluminum servo arms on flaps.
-Futaba S-3001 servos w/aluminum servo arms on throttles.
-Savox SC-0251 servo on rudder/tail wheel steering.
-all required servo/battery wiring le ads and ED-Klik 4-servo connectors utilized on both left & right wings and to receiver.
-HD Titanium servo linkages & HD horns on all flying surfaces
-aircraft has not yet flown and as usual, check your C/G first, and good to go!
Over $2,600 invested, but my loss is your gain. Cash sale at time of pick-up in Simpsonville SC. Plane is too large to ship, so please don't ask. More projects for sale will be posted as time permits, so stay tuned!
OL: 82.0"
My Feedback: (25)
Twin Stik
Good afternoon,
The Twin Stik was finished just before “Nall in the Fall”, and has not yet flown. All Stik’s fly very well, regardless of size or number of engines, especially given the large symmetrical wing. Sorry, shipping is not possible due to the size of the aircraft.
Thanks for looking!
Thanks for looking!
