DA 900 Pro Servos
DA 900 Pro Servos
4 Brand New DA900PRO Servos
High Performance Servo
*Massive torque and high speed
*Compatible with any radio using PWM control
*XBus compatible allowing 120 to 180 deg travel
*Slow start feature
*Nitrided steel gears for resistance to heat, wear, corrosion, and fatigue
*Special "B" gear (next to pinion gear) made from ULTEM with 572 deg heat resistance
*Super high quality Japanese ball bearings
*Ultra high performance brushless motor made in Japan
*Oversize 7mm/T25 Spline (Not compatible with standard 25T)
*6061 billet aluminum case machined in Japan
*Produced by Desert Aircraft Japan and RC Depot Japan
*Torque: 1012.4 oz @ 12.6v
*Speed: 0.11 sec/60 deg @ 12.6v
*Neutral: 1500 u.Sec
*MPU: 32 bit
*Input Voltage: 11.1-12.6v
*Weight: 3.0 oz , 86 g
*Dimensions: 40.6mm x 20.0mm x 40.0mm
Proprietary Servo Arms for DA650/900Pro servos ONLY (7mm/T25 Spline)
Brand New $219. Asking $210 each or all for $800
P.M. or message me at 520 484 4192
*Slow start feature
*MPU: 32 bit
