Half my Ad does not appear!
Hi Guys,
I am having a bit of trouble on one of my ads, and I am unsure on how to contact support.
http://www.rcuniverse.com/market/item.cfm?itemID=421676
On the ad above, half my ad is missing! On both Firefox 3 and IE the bottom half (After description) is non-existent.
Any ideas?
(This has been on and off, sometimes it works fine, sometimes it doesn't work!)
Volkan
Any ideas?
Volkan
Community Moderators
My Feedback: (42)
RE: Half my Ad does not appear!
I believe you are referring to the "Click Here" link correct? If so, it does not work because you are trying to insert a java script call in your ad. Marketplace ads do not support this. You should edit your ad to use plain HTML instead of java script.
