Set defaults
HI, I just posted a add, and set the shipping default as $15 in shipping, which did not show up in the add, This is not the first time this has happened, can you guys fix it now, please.
Rcpete http://www.rcuniverse.com/market/item.cfm?itemID=810210 |
RE: Set defaults
The default settings only work if you create an ad with the existing default. If you change the default, you must also change the non-default field. You can edit your ad and change the shipping options, then resubmit and the correct shipping information will be displayed.
| All times are GMT -8. The time now is 06:12 AM. |
