Collapseable forums
Marc,
I found where the little + / -'s are but the changes I make dont stick. Do you have to change it everytime you open RCU. Matter of fact, everytime I go back to the homepage none of the changes are staying. Can you edit which forums you see. Like if i never read the aerodynamnics forum can I edit it so it never shows up? |
Collapseable forums
You can only cancel out entire forums sub-categories...
for example you can collapse the wanted forum so you don't see the sub-categories on the home page. You cannot pick individually which wanted forums (ie helis, giant scale) will show or not. Only the master forums can collapse. When you return to the home page the settings for what you have collapsed or expanded should be as you left them. If not you might need to reload because of browser cache or if you haven't deleted your cookie since the upgrade a week or so ago delete it and it should remember your settings if the browser cache isn't the problem. marc |
| All times are GMT -8. The time now is 06:12 AM. |
