error on site
if i go to any page on the site that is not a fourm i get this message...
The web site you are accessing has experienced an unexpected error. Please contact the website administrator. The following information is meant for the website developer for debugging purposes. Error Occurred While Processing Request Session is invalid Resources: Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debug Output Settings, and select the Robust Exception Information option. Check the ColdFusion documentation to verify that you are using the correct syntax. Search the Knowledge Base to find a solution to your problem. Browser Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1) ; .NET CLR 1.0.3705; .NET CLR 1.1.4322; Media Center PC 4.0; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30) Remote Address 65.35.89.195 Referrer Date/Time 24-Jan-08 07:08 PM |
RE: error on site
its fixed now but i guess i posted this in the wrong help thread...
sorry. |
RE: error on site
No worries. More than likely, the particular server you were logged in to was in the process of, or about to be, rebooted.
| All times are GMT -8. The time now is 02:37 PM. |
