FMS Super Scorpion, 90mm Ducted Fan Jet
My Feedback: (508)
This Jet is in great condition... no problems at all...
It comes with a complete new set of retracts that I bought when I bought the jet... current retracts work fine...just backups as we fly off a grass field. I also bought two new servos for the jet and the associated linkages... all current servos work fine these two are backups.
The jet handles well and easily takes off our grass field. And it has plenty of power...
I'm selling it as I thought that I would like jets... but I'm just not a jet flyer...!!
The jet comes completely apart with screws and I can easily ship the plane using Greyhound.
From FMS:
The exciting FMS 90mm Super Scorpion takes inspiration from our popular 70mm version to bring you a larger jet with all the benefits "going bigger" can provide. The result is a feature rich rocket ship that's easy to handle whether you just want to cruise around or shoot through the sky like a speeding bullet. Functional flaps increase your flight envelope even further. Wide-track landing gear offers stable ground handling and is enhanced with the incorporation of all-metal, electric retracts that include shock-absorption and large wheels for smooth operation from paved or grass airfields. All eight control surfaces are individually linked with a dedicated metal-gear micro servo. Plus, you'll enjoy the precision and adjustability of ball-link equipped linkages.
The FMS 90mm Super Scorpion bolts together quickly; no glue required. Of course the lightweight construction with EPO means you can also count on a high-level of durability and performance. The power system utilizes a sweet-sounding 90mm 12-blade EDF system driven by a 3546-1900Kv brushless motor and 130A ESC combination for tremendous acceleration and speed when coupled with your high-C, 6S LiPo battery. If a twin-tail sport EDF has you excited about jet aerobatics, this Super Scorpion will not disappoint.
Features:
90mm EDF with a brushless 3546-size, 1900Kv motor
High-quality Predator 130A ESC with 10A external UBEC
Durable, all-metal shock absorbing electric retracts
Wide-track landing gear with large wheels for grass or paved field operation
12-blade EDF sound delivers an enhanced jet experience
6-Channel control with functional flaps
Metal-gear servos provide precision and reliability
Plug-in wing multi-connector makes assembly and disassembly simple
New ball-style control horns and linkages for greater precision
Easy, bolt-together assembly-no glue required
Vivid trim scheme with environmentally friendly water-based paint
Specs:
Aileron: Yes
CG (Center of Gravity): 150-160mm
Flying Weight: 3200g
Length: 1320mm (52.93 in)
Material: Foam
Motor Size: Brushless 3546-KV1900 (installed)
Radio: 6-Channel (not included)
Recommended Motor Battery: 22.2V 5000mAh 45C (not included)
Retracts: Yes
Servos: 13g Metal Analog, 17g Digital Metal (installed)
Speed Control: 130A with 10A UBEC (installed)
Wing Area: 29.4 sq.dm (455.7 sq.in)
Wing Loading: 108.8g/sq.dm (0.25 oz/in )
Wingspan: 1140mm (45.2 sq.in)
From FMS:
Features:
Specs:
Aileron: Yes
Material: Foam
Retracts: Yes
My Feedback: (508)
Super Scorpion
$280 plus PayPal would be ok... make offer
how are you going to get the plane...?
please let me know
thanks
larry
[email protected]
