Go Back  RCU Forums > Marketplace
Futaba T8J S-FHSS-2.4GHz Transmitter with Manual Only
Old 03-20-2022, 08:22 AM
jimmydelta
jimmydelta's Avatar
Default Futaba T8J S-FHSS-2.4GHz Transmitter with Manual Only
Futaba T8J S-FHSS-2.4GHz Transmitter with Manual:
Futaba T8J 8 Channel Transmitter Manual Only. Clean with little screen scratches as seen in photos but looks good and works Perfect. This was working on my son's Vario helicopter. Never had a problem. Will be shipped in a Priority Mail Box.Handling and Shipping $19.00 Priority Mail
This is the Futaba 8J 2.4GHz S-FHSS 8-Channel Airplane - Helicopter Radio System with an included R2008SB Receiver. The Futaba 8J has the performance and features you want, at a price you won't believe! Some of the awesome features you'll enjoy with the 8J include frequency-hopping security, the ability to transfer model data wirelessly between 8J transmitters, 6 programmable mixes (2 with curves), 5 heli flight conditions, 3-axis gyro support, 5-point pitch/throttle curves and a receiver with a full-range, dual internal antenna that can handle any application you can think of. All on-screen terms are spelled out on a backlit LCD screen. And everything is easily accessed and programmed with a jog dial and three buttons. The included R2008SB 2.4GHz S-FHSS receiver is S.Bus-compatible and features Dual Antenna Diversity. It also comes equipped to handle high voltage applications.
Precision. Programming ease. Versatility. It's all here with the 8J, and at a price that makes it one of the most incredible values in radio control. When you consider all of the functions that the 8J offers, along with its price point, you'll realize that this is one amazing system.
System Features:
Futaba S-FHSS 2.4GHz security (also compatible with FHSS)
Airplane and Helicopter modes
20 model memory
S.Bus-compatible S-FHSS receiver
Wireless transfer of model data to and from other 8J transmitters
10-character model and user naming
Large (128 x 64 dot) backlit LCD display
8 channels (one variable knob, five 2-position switches, two 3-position switches, one momentary switch, two digital levers)
Quick and easy programming using a jog dial and three buttons
End point adjustment
Dual Rate/Expo (any switch selectable)
Servo reversing
Sub Trim on all 8 channels
Digital Trims
Trim Step adjustability
ATL (Adjustable Travel Limit)
Failsafe on all 8 channels
Trainer mode
Throttle cut
Two Count-up/Count-down timers plus integrated timer
Model timer
Range check mode
Servo Monitor/Test
Auxiliary Channel switch/level assignability
Airplane Features:
Six programmable mixes (two with curves)
Flaperons with differential rate
Flap Trim
Differential Ailerons
V-tail mixing
Elevon
Ailevator
Snap Roll
Elevator/Flap mixing
Airbrake/Landing
Aileron/Rudder mixing
Flap/Elevator mixing
Gyro sensitivity
Throttle curve (5 points)
Pitch curve (5 points)
Throttle delay
Throttle/Needle mixing (5 points)
Idle down (any switch selectable)
Helicopter Features:
8 Swash Plate types
5 Flight Conditions (normal, idle up 1, idle up 2, idle up 3, hold)
Throttle curve (five points/four curves)
Pitch curve (five points/five curves)
Throttle hold
Hover pitch mixing
Hover throttle mixing
Gyro sensitivity/mixing
Governor setting/mixing
Hi/Lo Pitch mixing
Offset mixing
Condition delay
Throttle mixing (swash>throttle)
Throttle/Needle mixing (5 point curve)
Swash AFR
Swash mixing
Electronic swash ring
Throttle delay
Revolution mixing
Transmitter Specifications:
Type: 2-stick, 8-channel S-FHSS/FHSS selectable
Current Drain: 140mA
Receiver Specifications:
Type: R2008SB 2.4GHz S-FHSS 8-Channel Full-range flight receiver
Modes: S-FHSS or FHSS
Features: High-voltage operation, frequency-hopping Spread Spectrum design, Dual Antenna Diversity, S.Bus compatibility
Voltage Input: 4.8V-7.4V battery or regulated output from ESC
Compatible Batteries: NiCd, NiMH, LiPo, LiIon or LiFe
Dimensions: 0.98x1.69x0.55" (24.9x42.8x14.0mm)
Weight: 0.34 oz (9.5 g)
Includes:
8J Transmitter
Instruction Manual
Note:The mirror scratches are noticeable in the last photo. Take the photo with the control off because otherwise they cannot be seen. Does not have original box.
PayPal or Money Order...
jimmydelta is offline
Old 03-20-2022, 11:54 AM
jraycut
PM sent
jraycut is offline
Contact Us - Manage Preferences - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service -
