MRC Superbrain 969 Charger
AL
I have a Hobbyzone Super Cub I would like to have a charger that can handle 2 packs at the same time. I use the 8 cell 9.6volt batteries. Would this be a good charger for what I would be using it for. I will be eventually getting the 8 cell 9.6 volt 1400mAh packs from cheapbatterypacks.com. Will this be a good charger for those batteries? Any help is greatly appreciated.
Matt
Matt
AL
RE: MRC Superbrain 969 Charger
Ok I have now gone to brushless with my cub and am looking for a lipo pack. I found one of yours on ebay, http://cgi.ebay.com/RC-Lipo-Plane-Je...QQcmdZViewItem will this pack be good with a eflite park 450 motor. Or should i go with the 3S 1500mAh pack? Also the charger i have is the mrc977 super brain, will it work to charge this battery? Thank you for any help.
Matt
Matt
WA
Matt if you have the available space the 2100 3 cell is a great choice..........either pack will work. You'll just get a longer run time with the 2100 over the 1500. The nice thing about a high wing plane like a Cub is that you don't need to use full throttle that much......so you can really stretch out your flight times............if you need to see the dimensions of the packs go to our website www.MaxAmps.com , the dimensions are listed with each pack this will ensure you have the room for it.
Thanks for checking out MaxAmps and if you need any thing just let me know.
