RCU Forums
-   MaxAmps Support (https://www.rcuniverse.com/forum/maxamps-support-449/)
-   -   Battery Info (https://www.rcuniverse.com/forum/maxamps-support-449/6476416-battery-info.html)
DBono99 10-11-2007 05:39 AM
Battery Info
Hi
I just crashed my Sig Kobra..I need a replacement battery..I was using a Hyperion 3s2p4200 battery..
Here are my numbers 40 amps-440 watts,motor Hyperion 3025/08,50 Titan ESC, APC e 10x7 prop.
What would you suggest?
Thanks Dan
JAM MaxAmps 10-11-2007 08:26 AM
RE: Battery Info
If you want something close try this............. http://www.maxamps.com/Lipo-4200-111-Pack.htm . You should compare pack weight also just incase you need to make adjustments.
DBono99 10-11-2007 01:21 PM
RE: Battery Info
Hi I was leaning towards the 3s4000 much lighter then 3s2p4200..That (3s4000)should work in my application?
Thanks Dan
JAM MaxAmps 10-11-2007 01:33 PM
RE: Battery Info
Yes the 3S 4000 will also work very well.
DBono99 10-21-2007 06:00 AM
RE: Battery Info
Hi I'm only drawing 40 amps at WOT..Won't the 3s4000 be over kill since it's 20C Constant(80 amps.The 3s3000 might be a better choice? What the pro & cons going with 3000, less duration?
Thanks Dan
PS Do I get a MaxAmps T shirt with my order?
JAM MaxAmps 10-23-2007 04:56 PM
RE: Battery Info
Yes less duration.....it's up to you. If you want a shirt put it in the comment box and say that I ok'd it. Josh will call me to verify.
DBono99 10-24-2007 03:50 PM
RE: Battery Info
Hi Jason I called an ordered the 3s4000 today..Better to have more mah's. I can always use IT in future projects requring more amps..
Thanks Dan
DBono99 10-29-2007 06:48 PM
RE: Battery Info
Thanks Max Amps I oredered on a Thursday, by Saturday the battery was here. Wa. to NJ. in e days,can't beat that for speed..
Thanks Again Dan
