RCU Forums
-   MaxAmps Support (https://www.rcuniverse.com/forum/maxamps-support-449/)
-   -   2s/3s balancer (https://www.rcuniverse.com/forum/maxamps-support-449/7974604-2s-3s-balancer.html)
IIIxtremeIII 09-20-2008 11:05 PM
2s/3s balancer
I'm currently using a 2s Polyquest lipo in my TC4. I'm looking to purchase a 3s lipo from maxamps. I still want to use my 2s polyquest lipo if needed. I'm also going to be purchasing maxamps method balancer. What balancing tap should I get for the 3s lipo? Should I just get it to match the 2s polyquest(which I think would be the hyperion tap) so I don't have to purchase numerous balancing taps for the balancer? If not what would everyone recommend.
Thanks again
JAM MaxAmps 09-21-2008 12:37 PM
RE: 2s/3s balancer
Hyperion/Apache/Polyquest are all the same balance tap
Jason
IIIxtremeIII 09-23-2008 10:27 PM
RE: 2s/3s balancer
I currently have the Astroflight 109 charger. Will that charger be ok to use with the maxamps method balancer and a maxamp lipo? I know that's that notorious FAULT code that comes up at times. Just wanted to get your opinion on if the Astroflight 109 will be ok.
JAM MaxAmps 09-24-2008 02:59 PM
RE: 2s/3s balancer
Sorry I can't comment on that charger.
Jason
IIIxtremeIII 09-24-2008 10:53 PM
RE: 2s/3s balancer
No problem.. I just ordered the maxamps method balancer and a 3s 4000 lipo pack for my tc4.... i'm sure it will make my mamba max5700 scream...
emaXXman123 09-24-2008 11:03 PM
RE: 2s/3s balancer
that is for sure!!!! its will flyyyyyyy:D:D:D
