Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > Merlin Turbine Clinic
Reload this Page >
merlin 160 weak gas message
Merlin Turbine Clinic Support for Merlin Turbines is provided in this forum
Old 07-27-2012, 12:28 PM
umair56
Default merlin 160 weak gas message
Hi there when i start my merlin 160-kero start, it goes through all the start sequence and then it show me the message of "WEAK GAS" and stops . Any one can help in this issue
Old 07-28-2012, 03:00 AM
Xairflyer
Xairflyer's Avatar
Default RE: merlin 160 weak gas message
basically the gas level is not correct, the message says weak gas (not enough) but you could also get the same message if you have too much gas.
Always start with little gas and keep increasing it until you get reliable starts. Weak gas can also come up if the gas is cold.
Old 07-30-2012, 01:54 AM
umair56
The problem is solved by removing extension for the battery, connector to the extension were not sold properly battery was dropping voltage from 8.4 to 7.0 at the start sequence. Now when I give power when the data terminal says running, Rpm increase as i go above forty percent or increase throttle fast it tries to catch fire, Glow plug voltage are 6.4- Pump pw ignite-025....pump limit 625. do i have to change any parameter in Run menu.
Old 07-31-2012, 06:46 AM
lov2flyrc
My Feedback: (24)
lov2flyrc's Avatar
I suggest you discuss your issues with Gaspar directly; [email protected]
Impossible to diagnose without greater detail provided.
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
