Merlin 140 mounting options
My Feedback: (67)
While I do like the grooves in the case to contain the stock jetsMunt mounting rings, I am wondering if the M140 can be installed with the jetcat straps like these?
http://dreamworksrc.com/catalog/turb...rge-p-291.html
Basically, I'm looking to install it in a bypass previously set up for a P120 that has the mounts at 2 o'clock and 10 o'clock.
Thanks!
Thanks!
My Feedback: (67)
RE: Merlin 140 mounting options
ORIGINAL: scoeroo
Providing all is centered to the thrust tube, it wouldn't matter what straps are used....
Btw, do you have this turbine? How do you like it? Looks to have the best power to weight ratio on the market, wonder when the new version will be available?
My Feedback: (48)
I have a M90 and a M140 and am very happy with them. The kero start worksgreat, fast throttle response and good fuel consumption. Also Gaspar is great to work withif you have any questions. The M140X is suppose tocome out in early 2013, but you know how that goes. Hopefullyit'll be here by June.
Joe
Joe
