Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > Merlin Turbine Clinic
Reload this Page >
Jet munts 140 Xbl problem starting
Merlin Turbine Clinic Support for Merlin Turbines is provided in this forum
Old 12-30-2014, 08:14 PM
Hawkflyer
Default Jet munts 140 Xbl problem starting
Hi I have a new 140 Xbl first few starts were ok and then had problems. I gave it back to our local rep who got it running ok. I picked it up and am still having the same problems. Our local rep is overseas on holiday so I can't contact him for a while.
what happens on start up it goes through the normal start cycle including pumping fuel but does not light off. Eventually you get the ign fail message.
The radio I am using is a jr dx9 but have also tried a spektrum dx18 just in case it is the digital throtle trim causing a problem.
Old 12-31-2014, 03:30 AM
Jim Cattanach
Jim Cattanach's Avatar
Make sure your ecu battery is in good condition & fully charged. Also increase your glow power voltage by a couple of points.
Do not increase the glow power voltage above 7 volts.
Old 12-31-2014, 12:00 PM
joeflyer
My Feedback: (47)
It sounds like your ceramic heater may be shot. I had that problem on my M140 and had to send it in to have the heater replaced under warranty. If the heater is working you should hear a slight hum when you first initiate the start. Also if you put your hand on the case you should feel it get slightly warmer, and you should see the EGT increasing a few degrees. If that's not happening you need to send it in.
Joe
Old 12-31-2014, 01:50 PM
Hawkflyer
Thank you,
will try these things today
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
