Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > Merlin Turbine Clinic
Reload this Page >
Vt 80 slow spool in air
Merlin Turbine Clinic Support for Merlin Turbines is provided in this forum
Old 06-30-2015, 11:45 AM
RAPPTOR
My Feedback: (41)
Default Vt 80 slow spool in air
Vt80 throttle respons, in the air, is wayyyy slow.
Even from half stick..??
On the ground seems normal ??
Very hard to land . Big delay ,like 10 seconds.
Old 09-02-2015, 04:27 PM
stegl
If you bought it from Dreamworks check with Todd for possible solution
Old 09-05-2015, 03:22 AM
RAPPTOR
My Feedback: (41)
Old 09-07-2015, 02:09 PM
stegl
Sorry but was this the brushless pump version or earlier bushed pump. If using telemetry can you monitor pump voltage and rpm when in the air ?
Old 10-16-2015, 06:23 PM
gooseF22
gooseF22's Avatar
make sure the tank is vented properly.. also if you are using a felt clunk, then it might need to be drilled out..
Old 10-17-2015, 07:27 PM
stegl
Had my VT80 out in the Sprint today and had a perfect run on all 6 flights. there is a spool up selection that can be done on the GSU I believe. I remember seeing several throttle curves. Also wonder if the transmitter throttle curve is set up as non linear or something different ?
