Merlin Turbine Clinic Support for Merlin Turbines is provided in this forum
140 ECU settings
Old 02-28-2019, 09:18 AM
affas
affas's Avatar
Default 140 ECU settings
Hi,
Got a second hand 140 that starts ok, but hang at 6k and then a little too much flames I think.
Anyone with default ECU settings to check if the previous owner did some custom settings?
Menu Start :
Auto +: ?
Pump Start Ramp : ?
Glow Power : ?
Low Batt : ?
Start Power Ignit : ?
Starter Power Fuel Ramp: ?
RPM 100% Starter: ?
RPM Stop : ?
RPM Reconnect : ?
RPM Ignition: ?
Pump PW Ignition: ?
Engine Min Flow: ?
EGT End: ?
RPM Preheat K: ?
RPM Fuel Ramp: ?
Preheat Fuel: ?
Ignit Time Out: ?
Start Mode : ?
Menu Run :
Full Power : ?
Idle SPeed : ?
Stop Peed : ?
Start Min : ?
Max temp : ?
ACC DELAY : ?
DEC DELAY : ?
Stability Delay: ?
Pump Limit : ?
