Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > Merlin Turbine Clinic
Reload this Page >
ECU keeps starter motor on - FADEC V10
Merlin Turbine Clinic Support for Merlin Turbines is provided in this forum
Old 07-17-2020, 07:44 PM
sc0tt
My Feedback: (61)
sc0tt's Avatar
Default ECU keeps starter motor on - FADEC V10
I have a FADEC V10 ECU that is putting full power to the starter motor as soon as the battery is plugged in.
Is there a part on the circuit board that can be replaced by me or would the ECU need to be sent in or replaced?
Old 07-18-2020, 12:55 PM
FenderBean
FenderBean's Avatar
The Factory in Spain can repair boards try contacting them direct
Old 07-20-2020, 08:25 AM
joeflyer
My Feedback: (48)
Check to make sure that your wiring harness is connected correctly. If the battery plug is plugged into the ECU and you connect a battery to the pump connector it will do that.
A friend had this happen on his Kingtech with a V10 Fadec.
Old 07-20-2020, 12:41 PM
sc0tt
My Feedback: (61)
sc0tt's Avatar
Well I was hoping someone had an at home fix for a component on the circuit board similar to the older JetCat ECU's.
I just sent my ECU in for repair today. Wiring was fine, something went on the start circuit in the ECU (apparently a known issue)
Old 07-23-2020, 06:16 AM
hotspot 01
Ecu is no good send it back have had it happen a few times.
