M-160 is this kero start or not.
Hi I just purchased the 160 with the older gold esc and witch looks like kero plug,the installation looks like kero start one 4 mm hose to the kerosine opening and two 3mm hose witch one go to the kero plug and the other go to the propane opening the using one electro valve ,the esc have no kero start mode just manual and propane no kero start mode I did start the turbine with derect propane but never on kero with this setup the kerosine just not moving to initial th start ,what is the plug and is this kero start or propane . Thanks .
