Merlin 140XBL starting issue
Just throwing this out while we are waiting on a couple of call backs. I have a JetsMunt Merlin 140 XBL with the JetsMunt version of the Xicoy ECU. This is the one with the 3 wire interface to the turbine. During the start sequence the temperature reading drops from ambient to 0 as soon as the throttle stick is dropped to begin the sequence. The burner lights and fuel flows but the temp stays at 0. As a result, the start fails sometimes with a flooded engine. I have a brand new 2S 4000 mAh 50C ECU LiPo battery and I am told the igniter voltage was raised 0.2V from standard. Everyone I have spoken to tells me the temperature indication should start to rise from ambient as soon as the fuel ignites. It is acting to me like a buggy version of the ECU software. Anyone else experience this and if so how did you resolve? Thanks -Rob- |
Sounds like a defective temp probe to me or a defective connection of the temp probe to ECU. Other than than that Defective ECU could be the cause.
I suggest turning on the system to pre start mode and read the TC ambient temp on the data terminal , then with a heat gun hit the thermocouple at the exhaust , if the temp rises the TC is good
Next run the stick up & down to go into start-up sequence , if the data terminal goes strait to zero instantly you can then take it that the ecu is having issues Another check is to see if there is a high resistance crimp on the 3 wire connection cable that leads from the ecu to the turbine |
Originally Posted by ira d
(Post 12437032)
Just to close out this thread, I did hear back from Gaspar and he feels the problem is with the thermocouple. Albeit not that it is broken but rather the insulation / installation has been compromised. It does require changing out so the engine is off to be repaired.
