M200XBL expected values (startup time, idle & max PW)
Hello Keith, any chance you can provide an average PW value @idle and @full throttle for the M200XBL? Want to check my values to expected/standard figures. Also, what is the expected startup time from the moment you initiate startup to idle? Thank you in advance. lmk.. |
Hello, all those values will vary with setup and conditions. I would estimate low 100s for idles, I don’t have average start times. That will differ with ambient conditions, altitude and of course voltage, battery choice and setup. Gaspar might be able to give baseline from their data. |
Thank you. Not looking for exact numbers, an average value is all I need. Actually, if anyone has these values or perhaps a video of a 200 starting up that shows idle and full throttle PW would help. Just want to make sure my setup isn’t exhibiting an abnormality. |
[QUOTE=skunkwurk;12548604]
Actually, if anyone has these values or perhaps a video of a 200 starting up that shows idle and full throttle PW would help./QUOTE] Try Youtube |
I have. |
Hello Gaspar, hope all is well. Keith thought you may be able to provide baseline figures/data. When you have a second, could you provide numbers?
Again, I'm not looking for exact numbers, range is ok. I want to compare to my numbers to ensure my setup is within recommended specifications. Thank you. |
