Distance from engine to tailpipe?
Hi!
I have a m90 in a skymaster Hawk. What is the recomended distance from the engine to the tailpipe? Couldnt find anything in the m90 manual. Best regards Thomas |
RE: Distance from engine to tailpipe?
The correct distance depends on the pipe, airframe and bypass, so it isimpossibleto give aaccurate info for all airframes in the market. Werecommendto begin with 20mm gap, but this can be not the best setup on a particular plane. If the manual on the plane give arecommendedsetup, use it as it would be much more accurate than what we can say.
Gaspar |
