igniters?
igniters?
I was wondering what you guys use. I've used the Estes first fire. They seam to work ok. I've used nichrome wire which works pretty well, but the wires are so small. Is there larger size nichrome. Does anyone make their own igniters? Is their a way to reuse the first fires by putting new tips on. What to use? Those igniters aren't cheap.
Estes igniters work good but if You do clusters Quest makes great ones (when available). they are a bit on the scares side with the merging and moving with Aerotech.
Mr. Bob
Starlight Dude
Countyline Cycles and Hobbies
574-767-0660
Mr. Bob
Starlight Dude
574-767-0660
Are you lighting clusters or upper stages with avionics? Those would be reasons to consider using electric match based igniters.
For single C,D,E motors just use cheapo Estes igniters. Why are you short on igniters, are you burning up the igniters packed with the motors?
Yeah, I burnt out a few. I have a D & E motor no ignitors. But I have a burnt ignitor, and some nicrome wire. Didn't think igniters would be a big deal.
