Problem with 989 to charge Transmitter battery
Why I can''t charge Transmitter 8 cell If I connect 989 to the transmitter
NJ
RE: Problem with 989 to charge Transmitter battery
Reverse polarity protection in both the transmitter and the charger do not allow the charger to read the batteries voltage. If the charger can not detect the battery voltage then it can't charge. Do you see the voltage of the battery on the charger screen?
I don't see the voltage of the battery on the charger screen but win start the charging its show 38.61volt ??
In my old charger Triton2 it was charge the tx without any Problem
So if I can use the power .s. mode to cgarge the tx so what the best setting to charge the tx battery
NJ
If the battery voltage doesn't appear on the screen, then the charger doesn't recognize the battery as being there. You would have to remove the battery from the radio to charge it.
