Motors Disarming After a Short Time
Hi all. I'm having an issue where my motors will arm using a switch, and then after a few seconds, disarm. I'm using the Spektrum F400 and Raceflight with oneshot 30A Lumenier ESCs. Raceflight 1 won't detect my board, even when following the steps on Spektrum's website, so I don't have as many options in configuration. I'm wondering if this is happening because Motor Stop is enabled. In older versions you could disable or enable it, but in Raceflight 4.2.7 you don't have the option. I don't even see an option to calibrate the accelerometer. The motors will keep spinning up faster and faster if I move the throttle up and I know that is compensation for the props not being on. The only issue is that they disconnect about 2 seconds after arming with the switch and my board then disconnects from the computer and has to be unplugged and plugged back in to connect it (or I can arm once more and wait for it to stop again and then I don't have to unplug and re-plug).
