X525 with KK5.2 issues Help Please
Hello,
Just recently expanded into quads. Picked up four in a package deal. The X525 was a ARTF from what I can tell. It was built but never powered up.I was unable to find any info on the ESC's. They are black shrink wrap with no markings at all. I did not need to flash the board at all it was set up for X4 already. I added a spectrum Rx and bound it to my 12x.
Here is the issue. When I first move the rudder stick to initialize the board nothing happens. If I remove one ESC plug from the KK board (any one does not matter) It fires up fine. I then plug in the other ESC and it flies great. I can shut down and start up the board with no issues until I disconnect the battery then it starts all over again with disconnecting the ESC lead. I have all four ESC bec (red) leads still connected. I removed two from the esc connectors and tried it and it fould not fire up at all???
Any Ideas???
Brian
Any Ideas???
Brian
RE: X525 with KK5.2 issues Help Please
ORIGINAL: bart.tech
Hello,
Any Ideas???
Brian
Hello,
Any Ideas???
Brian
