Go Back  RCU Forums > RC Helicopters > Multi Rotor Helicopters
Heavy lift multirotor help!!!! >
Multi Rotor Helicopters Discuss Multi rotor RC Helicopter's here!
Old 08-21-2015, 02:28 PM
Default Heavy lift multirotor help!!!!
Hi all,
i m planning to build a heavy lift multi rotor.desired payload is around 25-30kg.
any suggestion welcome.not fussy abt electric or engine based design.
Thanks in Advance
Old 08-23-2015, 05:34 AM
I'm not sure exactly what you are asking for. I would suggest looking at heavy lift ideas on you-tube as a start. Your frame will need to be setup correctly for lifting that heavy of a payload. How many rotors are you looking for? What prop size? What is your budget?
Old 09-01-2015, 08:55 AM
CrazyCopter's Avatar
Hi
I'm disappointed in large electric copter. very expensive. a lot of batteries. I'm doing a test for the gasoline. I need help
https://life.indiegogo.com/fundraise...ies/x/11965580
Further work will be to create a hybrid system. We design Switched Reluctance motors and generators
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
