Blade 2 QX 350 Smart Mode
I am having problems with my Quad Blade 2 QX 350 inSmart Mode. Everything initalizes properly. GPS enable. I get a solid greenlight. I then activate the motors by moving the rudder gimble to the left andthen to the right. Motors start up. As I increase the throttle the quad beginsto lift. I applied forward up elevator right gimble and the quad moves forward.Now here is the problem. Once I rotate the quad either to the left or rightonly 90 deg. The forward motion up elevator the copter goes backwards. Downelevator the copter goes forward. It is as if the copter has servos and theyare reversed. I do not know why this happens..When I fly the copter in AP modesecond mode the copter flies correctly. I have not flown the copter in mode 3since I am not ready for this mode. I have been flying airplanes since 1986.
Any help on why this would be appreciated
