X-UFO, X-3D Vs UAVP OpenSource Quadrocopter
#76
RE: X-UFO, X-3D Vs UAVP OpenSource Quadrocopter
Wow, that is beautiful looking frame.
I do have a recommendation for the video. You can make it much more exciting by using the Mikrokopter to push around that vase of flowers on the coffee table. Can you show that in the next video, please?
Mike
Mike
#77
Way to go Nick,what motors and props (i assume epp1045) are you using?
So your MK is already up there,but did your uavp parts arrive yet?
#78
Nicoleto,
How was the delivery and experience regarding lipoly.de ? On time, etc. ? I've read about complaints. You noted you got the board pre-made. Was that the board-only or the populated one?
EEK
EEK
#79
This is one of the coolest looking ufo mods I've seen ... [link]http://forum.xufo.net/bb/viewtopic.php?t=6572&start=19[/link]
... true saucer-like around a X-3D X-BL frame.
--Eric--
--Eric--
#80
GA
#81
Hi, I working on my UAVP Quadrocopter and I have the following breakout board for anyone who willing to save $$ like me. The breakout board do not have any electronic parts. just the board only. asking $1.00 each. contact me if you needed them.
breakout board image
http://www.rcuniverse.com/market/item.cfm?itemId=346763
breakout board only
HMC6352
ADXRS300
LIS3LV20DQ
UAVP main board also available now [8D]
breakout board only
HMC6352
ADXRS300
LIS3LV20DQ
#82
How can I build my own quadcopter, I need a receiver and gyros to intergrate with the 4 motors. I don't know what to use.
#83
ORIGINAL: MB61101122
#84
TX
The UAVP firmware has been updated by Prof Greg Egan and is now know as the UAVX. It now has GPS position hold and return to home capability. The consortium of developers are continually adding new features. Here: http://www.rcgroups.com/forums/showthread.php?t=1093510
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index: www.rcgroups.com/forums/showthread.php?t=1097355
Cheers,
Jim
#85
I can Whole Heartedly recommend the Mikrokopter over the UAVP! I have had 2 UAVP's and neither came close to the stability and ease of flight as the MK. You can see my UAVP FPV video here
http://www.youtube.com/watch?v=bqD_6An4qiE
Don't get me wrong, it works and can be made bigger then the MK because it uses standard speed controls, and it's alot cheaper
However, the MK is a whole different beast! Allowing for extreme flight performance! like this:
http://www.youtube.com/watch?v=ELr3U4l5HkQ
I am hoping the new UAVX upgrade will bring the UAVP up to the performance of the MK, but we'll see.
MK all the way!!!
-Christo
#86
TX
I am also an MK owner since v1.0 to v1.3 and NAVI/GPS. You will be happy to know that the UAVX flies just as stable. It now includes a groundstation and waypoint navigation. See the links I posted above for the recent developments
Cheers,
Jim
Cheers,
Jim
#87
This is very encourageing to hear someone such as yourself say this. I have ordered my UAVX PIC and look forward to testing it out
