MVVS 30 Gas
MVVS 30 Gas
Hi,
Is there option to install the new MVVS-30 inverted on narrow caul ? is there special wrap around tune pipe header instead of the regular one ?
RE: MVVS 30 Gas
Apart from the muffler or pipe of your liking, you will need:
1x engine flange MTWF26
1x 90° bend MTWB1
1x 180° bend MTWB4
1x straight tube MTWkr1
1x coupler set 22 (teflon tube + clamps)
1x silver solder with flux cover MTWsl
Skill to put it all together
tools needed: propane torch, hacksaw (or dremel cutting disk), files, hammer, sandpaper.
Some stone bricks as fire resistant table. (I use a vermiculite slat)
1x 90° bend MTWB1
1x 180° bend MTWB4
