MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
58 carb
Old 05-29-2006, 11:02 PM
whaturi's Avatar
Default 58 carb
i have a new 58 and see that there are 3 fuel barbs on the carb. i know that one is vented to atmosphere and the other is the fuel supply. there is a third black plastic barb that i am not sure about though. what is it for? thanks!
Old 05-30-2006, 12:08 AM
DarZeelon's Avatar
Default RE: 58 carb
Vincent,
The third nipple on the carburettor is for operating the carburettor's integral fuel-pump.
It is closest to another nipple on the crankcase, where it gets pressure/vacuum pulses, that operate the diaphragm pump, which is inside the carburettor.
There should be some transparent tubing to connect between them.
This pump is integral to all Walbro and other power-tool carburettors.
It allows you to put the fuel tank back on the C/G.
I think that black one is for the fuel...
Old 05-30-2006, 05:59 AM
Default RE: 58 carb
The black is fuel,
The metal nipple on the cast cover is crankcase pulse line
The metal nipple on the sheet metal cover is membrane pressure vent line (fuel pressure reference)
Old 05-30-2006, 06:48 AM
whaturi's Avatar
Default RE: 58 carb
thank you very much.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
