MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
Evolution 58 ignition amp draw..
Old 08-28-2007, 08:32 PM
LowKey3D
LowKey3D's Avatar
Default Evolution 58 ignition amp draw..
What is the amperage draw on the newer ignition with the choke servo?
The reason I ask is that I get 3 to 4 flights before getting a low voltage reading from the led.
But the battery is at 7.4 volts at 1amp test. Does the ignition draw more.
I'm running 2 cell lion 2600mah.
Old 08-29-2007, 10:47 AM
BaldEagel
BaldEagel's Avatar
Default RE: Evolution 58 ignition amp draw..
Check the back panel of your ignition if its got a P marked on it you need 3xLixx or 9 Nixx, I find my draw off the battery is about 250mah per flight using the auto choke function.
Mike
Old 08-29-2007, 11:07 AM
pe reivers
I am quite sure it is the P-version if it flashes a warning at 7.4 Volts.
3xLiPo or 8xNiMH is needed for P-type
2xLiPo or 6xNiMH is needed for L-type and S-type ignitions
Old 08-30-2007, 10:57 PM
LowKey3D
LowKey3D's Avatar
OK Thanks for the info. I'll have to pull the cowl and check..
